There's a big hole under the master cylinder on the '12 w/auto tran, & there should be holes behind the dash end caps.
A lot of people use the foam filled holes behind the dash end caps. Did you check there too?I know, but this is a manual '13. they are different.
Nope the amp has a turn on lead which is wired to the head unit that tells the amp to turn on when the car is turned on.The switch question is something I'm interested as well and I have probably a stupid question to add. If you run an Amp directly from battery, won't it always be on?
There's a remote wire that comes off the amp that you can splice I don't remember exactly where lets say the radio ? So when the key turns on it turns the amp on / off .WhiskeyMike said:The switch question is something I'm interested as well and I have probably a stupid question to add. If you run an Amp directly from battery, won't it always be on?
Lol I was to slow ! Lollolpetewtf said:Nope the amp has a turn on lead which is wired to the head unit that tells the amp to turn on when the car is turned on.
I looked into this a white ago and was told no as its a complete unit....then I didn't look any further. Lol. But don't let that discourage you!ohioviper said:This is a good topic that might go along with a question I have. Im looking at running some lights .I plan to use a relay under the hood and run low amp control wire back to switch panel. Anyone know if you can get switches like the ones used for hill decent or the hazard flashers in that switch panel ? I would like my aux KC lights to be on a switch in that switch panel so it looks factory .Is it possible to add more switches to that panel ?
IIRC there is no room behind most any of the oem switch panels, some even have circuit boards directly behind them. Try something like the Daystar switch panel.This is a good topic that might go along with a question I have. Im looking at running some lights .I plan to use a relay under the hood and run low amp control wire back to switch panel. Anyone know if you can get switches like the ones used for hill decent or the hazard flashers in that switch panel ? I would like my aux KC lights to be on a switch in that switch panel so it looks factory .Is it possible to add more switches to that panel ?
http://www.wranglerforum.com/f33/what-lights-to-people-use-next-to-the-windshield-165085.htmlCan anyone post a couple pictures of where the pass through is on the 2013 manual? i am struggling to find the are you are talking about.
If you are trying to find it from the outside you won't find it. Do as I said above and run the fish through the area I said to. If it won't push through pull it out and angle it to the left. It will come out along the top edge of the fender but under the hood. It is a very small opening and can't possibly be seen until you run the fish tape.Can anyone post a couple pictures of where the pass through is on the 2013 manual? i am struggling to find the are you are talking about.
