My Jeeps having trouble keeping up on the highway and my best option is to re-gear. While I’m at it I might as well throw in some lockers since it would be cheaper while they’re installing the gears.
But here’s my deal - I’ve got the stock SE axles, which are not known to be super tough. If I put higher gears and lockers there’s a good chance I’m going to break something at some point.
So before I put money into the stock axles I want to consider replacing them with something stronger. What axles do I need to look out for? I’m looking for something that won’t really require fabrication and will just go right in. It’s a 97 TJ, and I’ve got 31” on it now will probably go no higher than 33/35. At some point an engine swap will be in the works too because although the 2.5 is pretty much bulletproof I need more power and when it goes I’m not putting another 4 cyl in it unless it’s a diesel.
