1 - 1 of 1 Posts
I am trying to find the length of a stock rear track bar and sway bar links. My wife's JKU had a rough country lift but she is on the shorter side and didn't like having to jump tp get in. I got new stock springs, pitman arm, and shocks. I removed the front track bar adapter and bolted it back in its original position on the axle without issue. When I removed the rear track bar adapter, I had to use a ratchet strap to pull the body to the left to get the track bar to bolt up (it was about 3/4 of a bolt hole off). That pushed the rear sway bar into the left tire, so I put the adapter bracket back on for now. My track bar is 41 inches long (bolt hole center to center). the sway bar links are 10 inches long. Thanks for any help.
Jason
2008 JKU
1 - 1 of 1 Posts
