1 - 20 of 25 Posts
I have a 3.21 gear ratio in my JK with 33" tires. In general, I'm actually quite happy with the performance. I'm not planning to go any bigger than my 33s. But on big hills, I feel like I could use just a little bit more power.
I don't want to regear; it's too expensive to be worth it for my purposes. I've read arguments for and against the CAI until my head spun. I've had a friend suggest a higher flow filter. What other ideas should I be looking at for just a few more horses under the hood?
Nothing short of a supercharger is going to make a difference. Intake and exhaust won't net you any noticeable difference.
Which motor do you have? 3.8 or 3.6?
You've got 285hp. Honestly if you want a little more "power" on hills...gears.
This... There is no more HP to be had except for adding a supercharger. Intake and exhaust just make more noise.
The fix is gearing. OP should have bought with 4.10.
GOT DOORS?
Yup, gears is it. Adding a CAI or catback UNLESS you tune the engine will give you nothing.
When you say hills,what elevation? It will naturally downshift (assuming auto). It can't be that bad. Also, after 60mph, aerodynamics is not your friend.
OP:
I'm a flatlander too. 3.6 liter. 3.21 gears. 33" tires.
If you have an auto transmission, you may be happy with just a programmer to adjust your transmission shift points. I was surprised how much difference the Procal made by adjusting the actual tire diameter.
I did regear, but honestly could have gotten by with just the programmer if I didn't pull a small trailer at Interstate speeds over the Rockies a couple times a year.
Discussion Starter · #11 ·
Yes, I should have bought it with better gearing. That's my fault for not knowing these things when I made the purchase. But I don't really have $3k for a re-gear. My local shop is quoting 12 hours per diff, plus the parts.
$3k is too much. $2-2.5 is plenty for a quality install, and you can get it done for less.
Mark
Sent from my SM-G935V using Tapatalk
Reactions: aqualungs
Shop around. That is obscenely high. 4wp just had a special for 1000 bucks.
As another poster mentioned. A tuner to fix your speedometer (calibrate tire size) will help with the shift points. Superchips flashcal can help with that.
Discussion Starter · #15 ·
I used a ProCal to fix the shift points for my tire size a long time ago, I'm afraid.
Yep, local axle shop does them all the time for $1050. $3k is obscene...
3k better include front & rear lockers
285 HP out of 3.6 liters is pretty amazing.
Not all that. The Nissan/Infiniti VQ 3.5 put out 306hp a dozen years ago, which which was a hoot in a car the size of a g35.
Mark
Reactions: Minion Wrangler
1 - 20 of 25 Posts
