Hello all i have a 2015 wrangler with about 3000 miles now on it and ive noticed lots of play in the driver side window when its about 4 inches down like while hitting bumps the window shakes so much but not falling out of track is this normal play ? They are power windows and info would be appreciated TIA.
Commercial Member
Same here, its the design...
it's under warranty bring it in.
The window shouldn't rattle about. It's should stay in place. If it's moving, something is giving. If you have movement up and down. The regulator isn't good or it isn't bolted down or not tighten to the window clips. If you have side to side movement. You're probably missing a trim that goes between the window and door.
The window tracks are loose inside the door or the felt has slipped below the tracks. Dealer can correct that.
