I have just recently discovered a rubber hose hanging loose inside the engine compartment.
Check the pictures here:
https://www.dropbox.com/sh/g9f20vmf8rqpkxg/GbLzqZxjTy
One shows the loose end that was just hanging inside, the other shows the valve attached to radiator that it was connected to.
Can someone tell me what it is for?
Where does it connect?
Thanks.
Thank you.
You're right, I have replaced the seal on the differential in fall, thinking that it was leaking.
Now, my thoughts are that the reason it was leaking was that the tube was not plugged in.
Got it plugged in.
Thanks again.
