Hey!
So I found a loose ground wire on the new (to me) JK as I was poking under the hood....it comes off the ground stud/nut on the driver side inner fender, and has two grounds, one going into a part of the harness, however, the second wire is loose and just dangling...(Please see pic below)
Anybody that can please check for me where this wire goes to????
Thanks in advance!!!
Mine is a 14, but should be similar. It connects to the mounting bolt of that computer thingy. Basically right below your left hand.
It just grounds the housing.
I went out at lunch and checked my 2010 JK. It runs under that line of relays. That silver plate the relays are on where your pinky finger is. It is on the bolt on that plate about where your wrist is.
I runs under the relays and up to the plate and inch or so down there is a bolt there is matching on the other side by where the wire is bolted if that helps. It gounds the plate the relays are on.
Hey!
Gunmn, Ob1, BeatM, thanks a buch!!!!
Found the screw, and connected that....as I was there I also disassembled and cleaned / reconnected three more grounds I found (One was loose!)...
I'm sure I can feel the JK idling much smoother than before!!!!
Thanks for the help!!
SP
