1 - 20 of 42 Posts
I mentioned this in an earlier thread but it wasnt the main point, and its droving me mad soo i think it deserves its own thread. When starting from a stop i get a loud pop. Not on bumps just from start. It has a 4 inch lift with lower control arms (not adjustable). It also has cam bolts for the sye kit. All bushings are changed, i thought its the trackbar so i put in a angled bracket ad its still there. Axle shafts seemfine because when i do toght turns no sound. Could it be my rear brake pads? Any other ideas?
Bump up, i woild really like some help on this. I have trackig this thing a long time now.
Bump up top, rely would like some sugestions to this prob. Tracking it a long time now.
Rear, but its strange i cant pinpoint where from the rear.
Check the trans and tcase mount it could be worn out so it jumps when power is transferred through it. Or I read in another thread to use a track bar with hemi joints
I think it is suspension arms/bushings.
Try accelerating from a stop and without putting on the brakes roll to a stop. Put it in neutral if you have to. Then start up without using the brakes and see if there is a pop.
When you stop you put a strain on the rear axle that will point the pinion downward. When you startup after that, if the bushings are worn on the suspension arms, the pinion will try to rotate up. You could also look at the pinion and see if it moves when someone trys to rock forward and backward with the brakes on.
Just a thought.
Trans mount changed a week ago. All bushings new in the rear. That why iam thinking it might be the brakes. The sound is as if something is hitting the drum. Like when hitting am empty pot.
There was movement of the whole axle a month ago, i realised that control arm bushings where bad so i thought that was making the pop, changed them. The upper control arm same thng changed it. Thought its the trans mount, changed it. Thought its tracbar ecause of the angle, got the braclet and changed bushings, same thing.
I had the same noise on acceleration after my 4" lift.
I traced it to the rear springs popping in the perch. I rotated each one 180 degrees and the popping has been gone for over a year.
Discussion Starter · #12 ·
Now thats something new to me. I will give it a look today. Thanks.
Discussion Starter · #14 ·
Adjusted brakes, rotated springs rechecked bushings and still there:( ran out of ideas.
Discussion Starter · #15 ·
They say its where the tires are, soo am guesing either brakes o axle shafs? But what could be bad in the shafts that make one pop and no popping on tight turns?
I had an issue with a weird noise in the rear, although it wasn't a clunk or a real loud bang. It was a hollow sound like you describe. Turns out it was just my exhaust hitting the right rear shock.
Discussion Starter · #17 ·
I wish it was that simple. Can figure it ou and i dont want to open up my rear end for that now.
If you have a large, smooth, flat surface and a driver you trust....
...lie on a creeper under the back of the rig. Hold on to frame/bumper and roll with the vehicle while driver moves forward/creates the pop so you can pinpoint location.
Of course, there are some risks inherent to this method... ;)
You mentioned you put in a trackbar bracket and replaced all bushings. Does this include the trackbar bushings? My trackbar was a bit loose and banging. Just had to tighten it up.
Discussion Starter · #20 ·
Actually we tried that around a month ago and the guy undr said it came from above the fuel tank, but there us nothing up there, thats when i replaced trackbar bushings.
1 - 20 of 42 Posts
