Last weekend I attempted to install LED lights to replace the OEM lights. I tested both before mounting back in the Jeep and both low and high beams worked. After I mounted them back in, I noticed the low beam was not working on the passenger side only. High beams work fine.
From the research I have done, there doesn't seem to be a fuse for the headlights. I have not had a chance to do much trouble shooting but I did reinstall the OEM bulbs and still have the same issue.
Has anybody had this issue and what was the cause?
Thanks
Retired Moderator
:welcome: to the Forum..:wavey:
I have no warning lights on so I have not checked for any codes. I'm hoping to have some time this week to look into this some more though.
Sounds like wire or connector issue.. what happen if you move/shake the wires when light is on?
I thought that also, but so far I have no flickering or anything when shaking it or driving. Going to take it back apart this week and see what I can figure out.
LEDs do have a polarity so I would check that first even if the OEM wiring is good. How do you explain they worked when on the bench but no on the car? I think the suggestion to check the wiring is a good one and try using some clips and switching the polarity.
Just a suggestion...
