1 - 12 of 12 Posts
Hello, I'm interested in hearing the best ways to increase low-end torque on a 2002 4.0L motor.
I have heard Exhaust and Air Intake are two good ways. I'd be interested in hearing what products exactly people recommend.
Thanks!
Donovan
That's a negative. Your gains will be minimal if not placebo
Make sure you are geared properly for your tires. Otherwise, the only way for more significant torque is forced induction or engine swap
X4 for a re-gear.
For low end torque gains outside of gearing I would suggest a stroker engine, with a head built to produce a wall of torque nearer the lower end of the curve. However, given proper gearing the standard 4.0 six cylinder is a fairly torquey engine as it sits in my opinion. It's not a stump pulling V-8 or a wall climbing diesel, but it's no slouch either.
Knows a couple things...
Converting to an automatic transmission provides 2-3x greater low-end torque. Yes, that's true, thanks to the magic of the automatic's torque converter. :)
converting to an automatic transmission provides 2-3x greater low-end torque. Yes, that's true, thanks to the magic of the automatic's torque converter. :)
lol!
regearing
Re-gearing is probably most bang for your buck
regearing looks complicated :) I'll hope I can find a good shop in Wisconsin.. When I went to 33" tires, my 5th gear now is not very usable, except on pristine days (no wind) and flat highways.
Thanks for all the comments.
Regearing is extremely easy. Write a check or give them your Mastercard, pick it up the next day. ;)
1 - 12 of 12 Posts
