I've lower my cold tire pressure from the recommended 35 psi to 30 psi. The ride is a lot softer.
Yup, but your MPG may suffer. Just be aware of that.
Yep when I had my 35's put on shop had em aired up to 65 lbs. on the way home I thought oh crap these are gonna suck ride was terrible. Got home and checked pressures, lowered them all down to about 32 psi and wow what a difference way better ride.
28 psi here all the time. Even wear, nice ride, mpg didn't suffer much. There are a ton of factors that go into setting the correct psi, and after all the trial and error including multiple chalk tests 28-29 psi was right for me on the street.
For on road I set mine to 37lbs when temp was 50 deg and there it has stayed. I find the ride just right and like already noted it does help a little with the mpg
