1 - 1 of 1 Posts
Just finished installing OME N198s on the rear end of my JKU Sport. I found the bushings on the lower end of the shock to be too wide to fit in the bracket. I ended up putting a crescent wrench on the bracket to open it up (quite a bit), then managed to get the bolt in and tighten it to the point the at it brought the bracket back to true.
I can't think of another solution besides maybe grinding/cutting down the bushings, which I wouldn't want to do, or cutting off the brackets and welding on larger brackets. Just wanting to know for future reference.
1 - 1 of 1 Posts
