Wrangler Forum banner
OK, so I went out to do an oil change and tire rotation today, oil change went fine, no problems. When I went to take off the first wheel is when the problems started, I managed to put the wrong size socket on my cross on the lug nut and rounded the corners. No biggie, I'll just put an 8 point on and take it off with the right sized socket... here's where it starts to get ugly... I start turning it with my breaker bar and it just keeps turning. I look closer and it seems the stud is turning in the rotor! and to make matters worse, the nut is now extremely distorted. I can probably get hold of the nut with one of those "grabs all rounded nut" sockets, but how can I keep the stud from spinning?
Your thoughts are appreciated.
Bummer , might try a air impact tighten to see if stud will bite some then loosen. IDK....
If they are the original lug nuts, they are most likely sleeved and the sleeve is what is spinning, I had the same problem. I ended up removing the damaged sleeve, (I don't remember how at this point) and then beat a smaller socket on the bare lug to remove it. i ruined the socket that i used. Good luck!
Yep, the OEM ones have a tin cap over the lug nut they will spin on the nut, you can either put a smaller socket on or you may be able to punch a hole in the tim cap and pry it off.
