Thinking of getting the Mamouth leveling pucks only kit that is on sale at Extreme. Pros/cons? Only want to run 33's and get a more aggressive appearance.
pucks will give you the clearance to run 33s with no issue.
I think the kit you are talking about is just the spacers. All that will do is increase your ride height the thickness of the spacers. If that is all you want, that is fine. But without other parts like bumpstop spacers, longer sway bar links, shock extensions, etc., all you are doing is increasing the ride height. It isn't really a lift in the traditional sense. It isn't really giving you additional clearance. If that is all you want, that is what it is so you should be good.
