They make a Non Comp bias tire that is dot approved. It comes in a 35" flavor as well. It has exact same tread pattern as the Sticky Comp versions.
· Premium Member
Pay attention to this if you go to order the stickies:
"important: For Cold Weather Storage (short-term or extended):
When the Maxxis competition tires are exposed to temperatures below 32ºF (0ºC), the unique racing rubber compounds used in these tires will lose their flexibility. This loss in flexibility can lead to potential cracking and other damage to the tire.
Do not move or operate the car with these tires mounted on the vehicle if conditions are below 32ºF (0ºC). Always store these tires indoors and at temperatures above 32ºF (0ºC). Avoid transporting and handling these tires in conditions below 32°F (0°C). Do not mount or dismount these tires when the surrounding work area temperature is under 50ºF (10ºC). Before mounting or dismounting, store these tires indoors for at least 24 hours in a temperature-controlled area of 68ºF (20ºC) or warmer. Remove these tires from the vehicle and deflate to half the normal air pressure during prolonged periods of non-use or storage.
