So I have recently done a new cam and crank gear, plus chain
i'm all put back together, I am timed at 7.5 degrees this is without the vac advance not hooked up, seem to have a misfire, everything is new, Never had anything like this before cam gear went.
also if I do my timing with the vac advanced unpluged and get with in 7-8 degrees where would it be once i plug it back in?
Back fire through the carb or out the tailpipe?
