1 - 11 of 11 Posts
Iv got a bad scrapping noise comming from the rear of my jeep. Its really bad when cold or after sitting for a bit but quites down a bit after driving. I just changed the tcase fluid and dif fluid niether were in horrible shape. Any ideas?
And also when me and a mate where change fluids he took the wrong plug out of tcase. The one he took out had a spring on it. It was located in front half of tcase and was around a 23-25mm bolt. I just put it back in because I had to get to work this morning, any ideas on what this is and if it will mess anything up?
Just when moving and sounds horrible when first you take off
Ya pads are good changed em about 4,000km ago
No rocks... It could be driveshaft as I have a 3 inch lift on a shorty but would that make a metal grinding noise only until warmed up?
Discussion Starter · #11 ·
Grease splitter??
1 - 11 of 11 Posts
