1 - 1 of 1 Posts
Hi all!
Been a lurker here for a while and always found great answers searching the forums. I finally registered because I can't find an answer for this question, and it's Saturday so I can't call Metalcloak.
I ordered the Metalcloak arched fenders, rocker guards, and extended rear corner guards. I've been trying to get the extended rear corner guards installed, and the instructions are for the regular corner guards, not the extended ones. The thing I can not figure out is how to mount the front bolt that is near the lower rear corner of the doors. There is a piece of body panel on the inside of the tub that is too close to use a rivet nut but is in the way of using a standard nut. How were you able to install this bolt? Hoping to get an answer quickly as I'm trying to finish this project up this weekend.
Thanks for your help!
1 - 1 of 1 Posts
