Sponsoring Vendor
After many requests, we finally saw the light and would like to introduce you to the Metalcloak Oil Pan Skid for the Jeep 4.0L engine.
Compatible with most 4.0L Configurations including TJ/LJ/MJ/XJ/YJ/ZJ/WJ, there may be minor modifications needed depending on your exhaust set up.
A simple, yet effective design, the Oil Pan Skid is:
  • Laser cut
  • 7GA steel
  • CNC formed
  • Bolt on (no welding required)
  • 3 times the strength of OE brackets
  • Mounts to existing attachment points
  • Clear Zinc for the best corrosion protection
As always, your feedback is appreciated.
I would probably buy this but it wont work because i have aftermarket bomb proof motor brackets so i couldn't bolt it to my engine without modifying it.
