OK..another plow question...i bought a 93 yj with the purpose of plowing..I also bought a 6.5' meyer w/the e47 plow pump. the meyer plow is an older..heavier one.
i put the plow on the jeep today and the front end is sagging way down. the axle is resting on the rubber bump stop.
questions- for the people with plows...do you run helper springs or air shocks.
If you have the original stock springs chances are they were flat to begin with. I had a 6.5' Fisher Speedcast on a 91 Toyota truck and it was a lot of weight on it. Chances are the Meyer is in the same class and is probably too heavy for the Jeep. I have a 91 YJ with a 4" lift and 5/8" boom shackles and just put a personal plow setup on it because I didn't want to run a commercial plow setup on the Jeep. I think they're just too heavy. I don't think air shocks would be the way to go. Beefing up the springs would be the answer.
If you're looking just for something for personal use here's what I did...
http://www.wranglerforum.com/f8/affordable-personal-plow-setup-70504.html
Just food for thought.
