Also im getting ready to start piecing together my coolant system. What radiator and hoses did you use? Looks like my factory jeep radiator inlet/outlet looks the same as the ford would use. Your setup looks great so wondering what you went with.
Yeah, the two real headaches were the coolant hoses and the power steering hose.Also im getting ready to start piecing together my coolant system. What radiator and hoses did you use? Looks like my factory jeep radiator inlet/outlet looks the same as the ford would use. Your setup looks great so wondering what you went with.
Awsome i appreciate that. That radiators not as expensive as i thought it would be good find. Good tip on the power steering Im still keeping my manual steering though lol will give me a workout.Yeah, the two real headaches were the coolant hoses and the power steering hose.
1. Radiator & hoses: I went with the custom radiator from these guys (Superior radiator - jeeps and wranglers) and the fox body hoses (I tried some others first and they didn't work) - although those hoses have to be manhandled into directions that they're not exactly fitted for. So far I've had no issues but it took a bit of cutting and yanking.
2. Power steering: I made this more complicated than I needed to because I was trying to avoid 'an expensive' custom hose. I tried all sorts of things but in the end I bought the Jeep hose for the rack side and then took that and the pump to a hydraulics place and they made me a hose with a new fitting on the Ford pump side for $80. NOTE! The OE Ford fitting for the PS pump is crap. I bought a whole Ford hose just for that fitting and it leaked from the start. Just jump to the end, take the pump to the hydraulics place and let them find a good fitting and put it onto the hose. I tried everything else before I went there because I THOUGHT it would be much more expensive than it was!
Im running a carburetor and have a ready to run distributor (has a ignition box built in) so the only wires i need to make the motor run is a 12v ignition power wire (wire that gets power when the key is on) and thats it. So really im running the motor on just the stock jeep harness. I cut out pretty much everything except the wires for the coolant temp and oil pressure this way i could use the factory gauges to monitor that stuff. Its an extremely simple setup which is what i want. I do however want to put a holley efi carb replacement on it one day but there like $1500 so that will wait lol.Jimbo, what are you doing for wiring? I had the 302 engine harness and the YJ body harness and PDC. And I spliced them one by one... there was a lot of reading and research but in the end there are only a dozen or so splices between the Ford & Jeep systems.
