I installed the AEV lift kit last week, and I made two mistakes:
1- I switched the bolts of the rear track bar. The bolt with the flynut is on the driver side, it should be on the other side.
2- the rear passenger coil is not index straight to the back, but to about a 3 o'clock angle.
Fixing both would require me to lift the Jeep of the ground, unbolt and lower the axle. Are either of these issues problematic?
Sent from my Nexus 6P using Tapatalk
I know RK usually requires the coils to face the rear but typically I don't think it matters.
Thanks. It's riding so much better now that I torqued the track bar and changed the broken steering stabilizer.
