Sold my '12 Wrangler so have these items I never got around to using. Prefer one big box instead of shipping single items but you'd have to pay shipping so whatever.
New items, never installed:
Gates Serpentine Belt: $15
Walker Products 235-1560 Crankshaft Position Sensor: $18
Mopar 5149141AF Camshaft Position Sensor, with valve cover O-ring seal: $30
Oil Filters '14+ x2: $5
Mopar Performance 68018109AA A/C and Heater Actuator: $35
Mopar Heated Seat Module: $40
Other:
Mopar Fuel Injector and 1/2 of Fuel injector O-ring set. (This may be the used one I kept but it is perfectly fine, I found it wasn't the problem) $10
DIY Intake Crossover tube. It uses the stock box/filter and eliminates the pinched accordian tube and intake silencer. Give it a shot, slight increase in noise and I swore it gave me a mpg or two (when not at WOT all the time)
$40
Also have an engine wiring harness from the '12 JKU Sahara, which did NOT end up as the main problem (I ultimately had the PCM replaced). It has some cut wires from removal but does have a lot of wire and all the connectors for anything custom you may want them for.
PM me Please,
Paypal accepted
