Im about done.... I have been having the p300 thru 306 misfire codes.
Heres what ive done.
New items...
bat
gas cap
spark plugs ngk mopar recommend
Coil pack
cam sensor
crank sensor
magnaflow hi flow cats
headers
muffler
air filter
Clydr head
Vacuum tubing
injector heat shields
injector o rings
Things ive checked
fuel pressure
compression
leak down test
cam n crank positioning
seafoam through intake. Intake totally cleaned during head replacement bottle's of lucus fuel stab n cleaner
throttle body cleaned like new
Im sure theres alot more ive replaced and done over the last 2 weeks things left I could do? Just replace injectors? Ecm? O2 even though it's not throwing an o2 code? Dunno im out 4 grand as of today.
New items...
bat
gas cap
Coil pack
cam sensor
crank sensor
headers
muffler
air filter
Clydr head
Vacuum tubing
injector o rings
Things ive checked
fuel pressure
compression
leak down test
