I've been getting this error code for awhile now (also the "multiple misfire and incorrect purge routing, but I've been told the multiple code pretty much goes with any misfire code) and have done the following to try and fix it:
1) Replaced spark plugs and gapped correctly.
2) Replaced spark wires.
3) Replaced cap and rotor
I'm pretty much down to only the coil or distributor left to replace in the ignition system to fix this problem and am not keen on spending anything else if I can avoid it. The cap does have some loose terminals though - could that be it?
Is there anything I'm overlooking? I know these things can be elusive but with almost all new parts I thought it would be fixed by now.
