I have a 89 with 4.2 and a auto trans with 2" BDS lift and 1" shackles. My question is do I need a 1" body lift to install a 1" MML? When I installed the lift kit I put on the t-case drop that come with the kit and had no vibs at all. I recently removed the t-case drop and have vibs all the time. I no I need a sye but I am eventually gona install a new t-case skid with less drop then the factory unit and want to wait till then to install the sye an new drive shaft without a double cardian ujoint. Will this setup be possible without the 1" body lift. I am trying to keep as low a center of gravity as possible with as much ground clearance as possible.
You can try the MML without a BL - you will likely have interference at the radiator shroud that you will have to deal with.
The BL will be great if you are planning on doing a tummy tuck and SYE later, so you may as well do it now...
A link to my tummy tuck build is in my signature. It's part of my 8.8 swap thread.
I'm out of town right now but I'm gona look and do some measuring when I get home and see if the 1" MML will work without the body lift for now and I not I'll reinstall the t-case drop for now.
I would install mml first and try it. The body lift is recommended for the flat belly.
