I'm moving up to Dana 60's & a Hemi in a week or two and I have some parts available. All these parts have about 5k miles on them, the Drive Shafts are about 3k.
Everything is still on the Jeep for you to check out before their removed.
Parts are from a 2014 JKRU
Front & Rear JKRU Axles:
Factory Lockers
Revolution Axles w/4:88 Gears with master install kit
PSC Hydro Steering Bracket (not PSC System)
Synergy front tie rod
Synergy front drag link
Synergy HD ball joints
Synergy Track bar bracket reinforcement
Reid Racing knuckles
Artec front axle truss/gussets/brackets
Artec rear axle truss/brackets
Poison Spyder bombshell diff covers
Axle set $4500.00
Drive Shafts:
Adams 1350 front & rear drive shafts
$500.00
Wheels & Tires:
Five 37x12.5x17 Cooper SST Pros's with 500miles (Not Wheeled)
Five 9x17 Raceline RT233 Al Monster Beadlocks w/ 4"BS (NO Scratches)
This set was new @ $4374, selling for $3500.00
I will not Separate Wheels & Tires, Axle Set, Drive Shafts
Note: Axles are set up for EVO DBL THD Coilcovers, you will have to remove the brackets and weld on the stock Coil bases.
Located in Yorba Linda Ca
>>>>>>>>>Sorry but "LOCAL PICK UP ONLY"<<<<<<<<<<
Bill 714-709-1900
As of right now I selling the Axles as a complete set Disc to Disc with all the steering components.
Thanks
Drive Shafts:
$500.00
Bill 714-709-1900
Text sent about the driveshafts
Driveshafts are sold, Complete
Axles disc to disc with Calipers, Wheels & Tires are separated and available
