O.K., I must be pretty stoopid but I'm having trouble keeping the ball joint from spinning on the sway bar end. There isn't an allen socket on the end of the stud to keep it from spinning. They have numbers stamped in the end. I'm pretty sure I'm not the first to deal with this but it's the first time I'm dealing with it. What have folks done to keep the stud from spinning?
Try putting a jack right under the joint if possible, it will put pressure (sort of like preloading it) and let you tighten it most likely...
