1 - 19 of 19 Posts
I just noticed on my 10A that one side rail sits up against jeep body and caused some minor dent and paint damage. It has seen some rocks...it is a rock rail...is this a function of a weak product or a faulty install? Any thoughts appreciated!
I dont think the mopar are bad, just not great. I dont think they are designed for serious rock sliding.
This is the enhanced slider with the step? If so its a bad design...if the rock hits he step it pushes the flat bar up and in to the body.
Retired Mod
Sorry your 10A got dinged up...that sucks being that it happened because you were using the vehicle the way it was meant (and advertised) to be used.
Fix it as best you can and go with better sliders if you are going to play in the rocks.
Ya know, if it was me, I'd go back to the dealership. Like Panthermark said, "...you were using the vehicle the way it was meant (and advertised) to be used"
Heck, it's called a "Rubicon Edition", not a "Rubicon-Bypass Edition".
To me, that is either a defect in materials, design or workmanship. Let the dealership & Jeep decide which one of the defects it is, fix the body and replace the Mopar Rock Rail.
Then once fixed, I'd sell those rails, and get some frame mounted rails, as you are obviously a rock hound... :thumb:
I would not do this. I mean if you got a dent in your bumper would would consider that defect?
You are going to want not just a rocker protector by a ture slider that mounts to the frame. LOD Shrockworks White knock off road VKS fab. TJM Poison spyder
Great aggressive selection, thx. How about ARB-less aggressive but good strong protection?
Might as well ask them to replace your undercarriage armor as well. I mean, I am sure its bent if you are a "rock hound". Ask them if you can have them repaint any of the scratches you may have on your axles or wheels. Have them replace the carpet from your shoes touching that as well. You might as well tell them it got dirty when you drove it off the lot and you bought a clean one and you would like Jeep to keep it in the same clean state.
Ridiculous.
Ridiculous.
This is even more hilarious becasue I know you and your Jeep!
I think the bad design aspect is that it is attached to the body and not the frame. It's designed to take mild contact or "slide" over rocks. It's not designed to take the weight of your vehicle as it bounces on a boulder.
The pictures I post were I ones I was considering.
ARB makes great strong products. This is the best picture I could find showing how they are mounted. They do mount to the frame.
I ended up going with the TJM sliders for the mount of coverage they provide. I would describe them as mini boat sliders as they not only protect the rocker by also cover most of the frame.
Ask and ye may recieve.
Nothing ventured, nothing gained. Why would you not want to ask?
A dent in the bumper would not damage the body, because the bumper is attached to the frame. Unless someone got in a major collision, then yeah, it might be difficult to go into the dealership with a bent frame, and ask them to fix the body and the bumper...
:rofl2:
The pictures I post were I ones I was considering. ARB makes great strong products. This is the best picture I could find showing how they are mounted. They do mount to the frame. I ended up going with the TJM sliders for the mount of coverage they provide. I would describe them as mini boat sliders as they not only protect the rocker by also cover most of the frame.
The TJM sliders are very nice and for the money you can't beat them!
:rofl2:
In all of the commercials for jeeps I have not seen them drop it on a slider. Saying/advertising offroad use does not constitute dropping it on rocks.
Sorry to hear about the Mopar rails. If playing on rocks you definitely want a frame mount. Some also do weld mount (I think EVO?). I went with Fab Fours sliders/rocker panel. It is a single piece that both frame and body mounts. It covers the entire seam in many pounds of steel boatside from rocker to frame and gives a nice ledge that works as a solid step. Spendy and involved putting a lot of holes in my Jeep to attach the rocker piece at the top to the body, but I know when I bring the weight of my Jeep down on them, worst I am walking away with is some scratches in the powder coating. Each side is literally a side "bumper".
It appears we need to look maybe at Schrockguards if we are going to play on the rocks.
I was not aware the MOPARs were NOT mounted to the frame.....
Jeep, ShrockWorks
1 - 19 of 19 Posts
