Thanks!! Guess they’re the same.You can see the cross-reference from the Mopar SP149125AE part number to Champion here:
Car Part Number Results for Champion Auto Parts
Champion has car filters, spark plugs and wiper blades available for a wide range of vehicles. Discover what part numbers are available for your machine.www.championautoparts.com
Those are Mopar from the dealer 16 each.It’s a lot of work to change plugs so I would go with the proper factory original plugs. Purchased from the dealer or an official Mopar site.
Those were Mopar at 16 a peice. If your saying Bosch is costly, I’m afraid to ask.I threw an upgraded set of plugs in my old XJ when it was due for its first set- pre-gapped Bosch Iridium plugs. They were costly compared to the OEM Champions, had a bit of sticker shock at the parts counter. I pulled them 60,000 km later to see f they needed replacement during routine maintenance, and the gaps were the same, the plugs were clean, and the electrodes still looked perfect. I threw them back in and drove on.
I suppose if you want to lengthen the interval for changing the plugs on a JK (which doesn't have the plugs in quite as accessible a spot), it wouldn't hurt to go with a premium alternative over OEM.
But doesn’t Champion make the Mopar plug? 🤨Those were Mopar at 16 a peice. If your saying Bosch is costly, I’m afraid to ask.
What’s funny is I asked the parts guy what the difference between mopar and champion and he said, “I wouldn’t put Champion in my lawnmower”.
I’m at 80K and my plugs are burnt. I don’t think 100k is an accurate interval.
YesBut doesn’t Champion make the Mopar plug?![]()
What a dick. Champion makes the best lawnmower spark plugs. I suppose one can have a certain amount of success with Champion plugs or else they wouldn't still be in business, but my experience does not bear this out. In carburetted engines AC or Autolite last longer and are far less likely to foul. Edelbrock had a recommendation for Champion with its heads (big block Chevy, 11.5:1, twin Dominators) and they were awful. For computer engines I have never had a failure or poor life from NGK.Those were Mopar at 16 a peice. If your saying Bosch is costly, I’m afraid to ask.
Keep in mind that the parts guy works a low paying parts counter job. That is probably because he is not highly qualified at other things. If he were a highly skilled and qualified mechanic, he would probably be out in the shop repairing vehicles.Those were Mopar at 16 a peice. If your saying Bosch is costly, I’m afraid to ask.
In my 2013 JKU, the plugs are iridium. When I changed the factory plugs, the factory plugs that I removed were the same iridium model that Champion said my Jeep required. I just looked on the Champion web site and your 2012 takes the same iridium plugs as the 2013.But the OEMs (for at least the older JK's, like my '12) are not iridium, right? I'd like to go with iridium, but with the Lifetime warranty, I need to stick with OEM
