I'm trying to gain some HP. Any gain by removing AC? Seems like it would only reduce HP when in use. Am I correct in this thinking?
The AC uses very little horse power. You would never notice the difference. The best bang for the buck to get noticeable power gains is to regear.
From your prior posts, it looks like you have 33” tires on a TJ. If that’s the case, I am guessing you desperately need to regear
The only way to increase horsepower, is to pull that anemic 3.6 out and slip in a Cummins 😊
2017 JKUR 3.5" MC Kit
Doesn't the regear impact torque favorably but hp negatively?
Not really, the gear ratio multiplies both torque and horsepower. So a shorter gear, higher ratio number, multiplies both torque and horsepower more than a taller gear, lower ratio number.
Technically horsepower is just a calculated value anyway.
It would lower the theoretical top speed, but we aren’t going to be anywhere near there with a Jeep.
I read an article once which claimed the AC uses about the same amount of energy as running with the windows open on the highway. In other words.... not much.
