1 - 9 of 9 Posts
Just wanted to share with everyone that mothers plastic polish works wonders. Just got done doing half of my windows and this stuff has made them 100% better. Mind you it didnt remove my deep scratches but it lightened them and took out all the little ones. Ill find out tomorrow if using a buffer helps more.
What other products do you guys use to clean up your soft windows and soft top??
Just want to add that adding the use of a good buffer made this job a lot easier and my windows are better then when i first bought the jeep. Took it out wheeling on some tight trails and i also noticed this stuff does seem to add a bit of protection. It has my approval :thumb:
Did the same thing with mine and made a huge difference. Then went back and did it again and saw an improvement. (all by hand on this one) Adds a waxed feel to the plastic windows and is easy to use. I wiped mine with a wet towel first to remove as much dirt as I could then went to work.
1 - 9 of 9 Posts
