I just installed a 1 inch motor mount lift On my 2004 tj and a belly pan skid plate. After we finish I took it for a ride and noticed a noise coming from what sounds like the Tranny? You can only hear ir on the inside of the jeep though. Any help here would greatly help thanks!
During the install of the mml, one of the first steps is to remove/loosen the trans mount nuts before jacking up the motor. Did you do this? Did you tighten them back up upon completion?
Sorry, missed the skid plate install. I'd still suggest going through all fasteners to triple check.
I'm going to go back through everything tmw again. I just can't figure out what it could be though
Tcase shifter linkage hitting the tub.... Many times with a belly up skid (assuming that's what you meant) you have to deal with linkage clearance. Brackets exist to resolve that problem. I forgot who, seems like Skyjacker made one, and somebody else. Easily googled, "transfer case relocation bracket".
