Just curious if any of you has had to replace your motor mounts, and how difficult was it? I have have a 90 YJ wrangler and the motor mount are shot. The jeep shakes like crazy. I hope the new mounts I ordered from Quadratec make a difference
I have a 90 YJ with 4.2. I thought it was gonna be simple but the driver side bolt that goes through the rubber is long and hit against my power steering pump. When I tried to loosen the bolt for the pump it snapped without that much torque against it. That turned into a bit of a problem had to drill it out. When I put the long bolt back I put it in from the firewall. Without the unforeseen problems it is a pretty simple job.
4 banger I hear are a SOB. my 4.0 was piece of cake. just loosen all hardware to give you the play you need for your new MM. replacing trashed mounts with new is amazing
A forum community dedicated to Jeep Wrangler owners and enthusiasts. Come join the discussion about reviews, performance, trail riding, gear, suspension, tires, classifieds, troubleshooting, maintenance, for all JL, JT, JK, TJ, YJ, and CJ models!
