Okay my jeep is a 95' YJ and I know how to drive it on the road. But tomorrow I'm taking it off the road and into the mud! I was wondering how exactly do I go mudding on a stick?! Like do I shift? Stay at first? 4 hi 4 low. And it's a 3.5 inch lift with 33 12.5 inch tires. Please all the advise and even better a step by step would be awesome thanks!
I almost always stay in 1st gear in my five speed while off roading. In 4LO I already have so much torque I never need to shift really. But if you need to shift - your instincts will take over.
Hope this helped! Good luck! :thumb:
are you in a 4 or 6 cylinder ? i like to use 4 hi in the mud because you can run a higher rpm and mash it if you have to 4 lo is more fore if you get stuck or hill climbing i run 1st and 2nd usually and im in a 6 cylinder all my buddies have 4 cylinders and they always use 2nd
I always get water and dirt in the tranny through the shift tower when mudding or water crossing. I don't mud anymore because of it
4 cylinder. So you think I should go 2nd ?
try 1st and 2nd youll know when you and if you need to shift like stated above have fun your jeep will tell you what it wants you to do i have a buddy in a 4 cylinder ive seen him get to 4th in a mud hole its all about how much you like to tare your jeep up just have fun and be careful muddin is a good way to tare stuff up
i have found my rig,2.5 5 speed will go anywhere in 4 low and 3rd running 33s
