Making a mess today
, but my basic lift in on
20210604_171258 by RAM RSM, on Flickr
Wanted to keep things as simple as possible, I added the Synergy fixed front LCA's in the end cause i wanted to keep my caster up. All in all she drives great just like stock. Don't know exactly what's going on but this Jeep drives a lot nicer stock than my 13 did stock, so i just did a small set of spacers to keep the cost down for now, but added longer shocks and all the other little stuff i thought i needed to make the kit a little more complete
So this was my initial suspension setup:
Rubicon Express RE1325 1.75" front spacers
Daystar KJ091140BK 0.75" rear spacers
Synery 8097 JK rear coil Wedges
RXJ713 front shocks,24.14" extended - 14.80" compressed
RXJ714 rear shocks, 25.00" extended -15.30" compressed
Teraflex 4304400 rear brake line bracket
RE 1380 2" front bumpstop
RE 1387 2" rear bumpstops
Synergy 8047 Fixed front LCA's
JKS 2034 quick disconnects
RE1158 rear sway bar links
Synergy 8047 is 22 3/4" eye to eye
2021-06-05_09-11-49 by RAM RSM, on Flickr
2021-06-05_09-11-58 by RAM RSM, on Flickr
The stockers are 22 9/16
2021-06-05_09-12-07 by RAM RSM, on Flickr
Also took this picture to show the angles of the sway bars in stock trim
front
20210604_151715 by RAM RSM, on Flickr
rear
2021-06-05_09-12-16 by RAM RSM, on Flickr
And finished product
2021-06-06_11-39-12 by RAM RSM, on Flickr
2021-06-05_09-12-30 by RAM RSM, on Flickr
2021-06-05_09-12-35 by RAM RSM, on Flickr
2021-06-05_09-12-40 by RAM RSM, on Flickr
2021-06-05_09-12-45 by RAM RSM, on Flickr
2021-06-05_09-13-05 by RAM RSM, on Flickr
2021-06-05_09-13-00 by RAM RSM, on Flickr
2021-06-05_09-12-55 by RAM RSM, on Flickr
2021-06-05_09-12-50 by RAM RSM, on Flickr
I had ordered Yokohama 285/75/17 but i cancelled the order because Discount Tires Direct messed up and they didn't have the tires in stock. i'll check with my local Americas Tires on Monday.
I'll also be scheduling my regear fairly soon, going with 4.56's. I already ordered the security cable for to unlock my odb2 port from Hptuners and i have it in the garage. so i'll be able to change tire size and gear size. Will install soon. I'll also try AlfaOBD in the Jeep and see if can configure the same stuff i've done with my RAM 1500. I'd assume it'll work since i've seen Jeep in the menu. Will see.
front
rear
