1 - 1 of 1 Posts
Mods
Fully caged , full engine cage , dual optima battery's , live wire plug wires , k&n intake , volant throttle body spacer , borla long tube headers , hooker headers glass pack , Arab compressor , power tank , Arb lockers , 5:13 spicer gears , chromoly shafts , Wilwood 4 piston calipers , synergy tie tod , custom drag link & track bar up front w/ 7/8 helms , 4x4 armor front diff skid plate , rock hard 4x4 full belly skid plate , 1" wheel spacers , pro comp beadlocks , 39" Mickey Thompson Baja claw ttc bias ply's, mishimoto aluminum radiator and 170? race thermostat, mishimoto trans cooler , 200 amp alternator , psc steering pump and box , smittybilt xrc stinger , smittybilt xrc10k winch w/ synthetic rope & factor 55 pro link, smittybilt xrc front & rear armor fenders , xrc rock sliders , rigid amber rock lights , tough light 30" led bar , 4 pods , Baja designs led headlights , 14" king 2.0 coilovers w/ reservoir & 14" king 2.5 3 tube bypasses w/ reservoir up front , Currie anti-rock sway bars front and rear , tom woods custom drive shafts , Currie short arm kit , atlas 2 speed 5:3:1 transfer case , built transmission w/ 5 point planetary , billet torque converter, bigger clutch pack and corvette servos , bullydog triple dog gt jeep programmer , smittybilt xrc sport cage , pci race radio , police siren & pa , alpine double din indash navigation, alpine type r speakers & tweeters , alpine 4K amp & 10" type r 3000 watt sub , drake hood latches , custom rear suspension running king 16" 3.0 coilovers thru the floor into custom shock tower tied into the cage w/ 6 spots where the cage is tied into the frame , concealed cary lock box under drivers seat , crow 4 point harnesses , msd igniton g2 rear diff cover , Currie rock jock rear track bar , king 2.0 4" bumpstops in rear , stainless brake lines , 36" rigid rear facing light bar w/ brake,dust light, blue light mounted to cage in rear , custom welded battery tray , master cylinder mount , fuse block mount , evap canister skid and relocation bracket , sleeved and gusseted front and rear axles
1 - 1 of 1 Posts
