hi im new to this forum, im having a issue with my gas gauge..it reads full till about 180 miles then drops down...what could be a easy fix? is it the float?
Welcome to the club I have one of those to. Haven't really seen a good solution here to the gauge issue most say set the trip meter and figure out when you should buy gas. I am sure someone else will chime in aand add to this one.
I have one with the same problem.I pulled the tank and cleaned the resister on the float arm.I then put an ohm meter on it and it still does not drop the resistance smooth as it should.the only fix for that is to replace the tank sending unit which I have not been able to find without replacing the entire unit,fuel pump and all
