Hello everyone,
I'm hoping this is common and someone can give me some advise. So like the title states, I changed my master/slave cylinder with a pre bled system and is quite squeaky. It sounds like its coming from the slave cylinder and traveling up into the cabin. Other than the clutch being pretty stiff, I can shift through the gears fine. Do you think I should return the unit and get another or is something that I need to break in? I have not driven it long only a few miles since the change. Any help would be great. Thank you!
I replaced mine a few years ago with a new Mopar unit, started squeaking just like the old one.
It would seem they all start squeaking eventually, it doesn’t effect any functionality that I’ve seen
Sure it's not coming from the the clutch pedal pivot bushing. Try lubing it up and see what happens.
