1 - 20 of 45 Posts
My fenders are a very patchy gray/light gray. They are factory. Any suggestions on a upgrade? Or can they be painted?
I have a 98 Sport. Stock suspension. Currently 30x9.5x15 tires, but will upgrade to 31x10.5x15 in the very near future.
Painted mine with bumper paint. It allows the flares to flex without the paint cracking. UR
Krylon Fusion black gloss spray paint is what I used on mine. Didn't even take them off, just taped off the edges and turn signals then painted. Its been six months and looks good as the day I did it.
I leave mine faded just like my hair and beard.
-Wash them thoroughly with soap and water
-Once dry rough them up with some Scotch Brite pads so the paint can adhere
-Either take them off or leave them on
-If you left them on tape off your rig where you don't want paint
-paint with Krylon Fusion
Remember: Do several light coats with 5-10 minutes between coats
After the first coat you should still be able to see the faded color underneath
- give them 3-4 coats and allow them as much time as you can to dry before driving with them on
Remember: Depending on where you live you may need to take the weather into consideration. Paint is ideally applied/dried/cured in temperatures 65 and above. If it is cold it will take a long time to dry and may remain tacky for several days. If it is cold where you live do it inside a garage where you can keep it warm and maintain ventilation. If you live in warm climates year round, then screw you! haha just kidding
good luck
I did the same exact thing not quite six months ago. It has held up great, I've been very impressed. No cracking or peeling, even back by the filler where gas drips all the time. I definitely suggest Krylon Fusion. Took about a can and a half or so, if I recall.
Jeeper
Trim them before you paint them...... you'll be glad you did :)
:rofl: Does that mean I should have made mine blond? :rofl: (no, last I looked I don't have a beard.....)
Hardcore Jeeper
Before you take a blowtorch to your fenders...Quadratec sells a reconditioning kit called "Forever Black" which supposedly restores your plastic fenders. Haven't tried it myself but, I just ordered it and it should be on its way soon.
Here's a link for it:
Forever Black FB080 - Forever BLACK™ Cleaner & Reconditioner Combo - Quadratec
I have used this product (or something similar) lasted maybe 6 months on the flairs, however, my faded interior pieces are all nice and black again, just don't leave them out in the sun all day.
1 - 20 of 45 Posts
