1 - 20 of 31 Posts
2.5L>4.0L
Bumper is rusted on. My grandpa is coming over tomorrow to finish. So far. Took it out of the box and removed the lights off the bumper.
2.5L>4.0L
Isnt the only thing just the head of the bolt on the underside or is their something else on the inside of bumper that needs to come off?
there is like 2 bolts ontop and 2 bolts on the bottom on each side If I remember. They are going to be rusted to shit on the bottom depending on where you live so god bless! lol I couldn't get them I needed a strong friend to do it.
Knows a couple things...
Heat them up and they should come right out
That's a very good suggestion so long as it is heated up enough.
Make sure to use a good quality fresh T-55 and with an adapter so it can be mounted onto a 1/2" drive ratchet wrench or, better, a slightly longer breaker bar. Those particular bolts will be too tight for a 3/8" drive wrench.
2.5L>4.0L
Discussion Starter · #14 ·
I've done everything everyone has said. I have applied 200 foot pound torque an still not budging. Need and air wrench. Take 10 seconds to get it off.
Trust me that won't be the only use you have for the grinder! You can get a cheap one from harbor freight if you don't want to put alot into one. Put a little more time into it, heat it with a torch, use a hammer to tap it to help break it free, generous amounts of penetrating oil ( be careful of oil and torch). When all else fails the old trick of putting tension on the bolt with your wrench and tapping with a hammer simultaneously like an impact wrench.
Retired Moderator
You don't want to use an impact on a rusty torx bolt. Both will be stripped in seconds.
You are not the first to have this type of problem. A small propane torch can be purchased at any hardware store for very little. Heat them up good.
These bolts are self tapping and installed with an impact at the factory. They will come out hard the entire way. Once you get them out replace them with button head cap screws. 1/2-13
1 - 20 of 31 Posts
