1 - 20 of 126 Posts
I bought my tj 1.5 yrs
I've owned 11 4x4s and lifted most of them, so I decided to not lift my jeep and build it to crawl/flex and be able to get huge tires under it on stock springs.
New stinger bumper
D-rings, rock sliders and steering box skid
Modern classic enterprises flat fenders install
Traced the outline on my fender with a black sharpie
No turning back now.... I used a 4" electric cut off disk, kinda dusty but it worked.
Make sure to clean the metal with a good cleaner (i used 409)
flat fenders installed turn signals are mounted there for a few days til i get new lights.
new LED's installed front and rear with the proper flasher
Test fit of 33x12.5s
a bit wide for my taste.
Flex'n on snow mound with new tires and winch
Stage one finished-
Up grades include: smittybuilt f/r bumper & rock sliders, gas tank skid, MCE flat fenders, removal of rear flares, steering box skid, 33x10.5 TSL's, ARB d-rings, Cobra cb, LED fornt marker lights and rear 4" brake lights, 8000lbs winch.how it sits as of winter 2k10
poser flex'n
Discussion Starter #2
built a new stinger/winch bumper
time to start the Hi-line front fenders
I cut the hood with a jig saw and a long blade. I'm moving the fenders 3" up
Drivers side hi-line installed for another test fit.
passenger side installed
hi-line installed poser flex again.
still need to fix the hood
Long travel front shocks
new front shock sitting next to stock front shock
getting closer
mock up of shock in place(full extended)
Fender off again time to weld in the new shock towers:D
Hood closed
new steps
cage build
all welded in and painted cage is a thru the dash design
Rear outboard shocks
about where I'm going to cut.
Mock up of shock tower, frame still needs to be cut a bit
shock tac'd in place and cycling the suspension
Full compression bumpstop
thats plenty of room
custom lower shock tabs
another poser flex on a 32" snow mound on stock 2.5L springs
I just installed some 4.OL springs up front, it leveled the jeep out (the winch pulled the front end down) and flexes much better with the 2.5L spring I'd unseat the spring an inch at full droop with the 4,.0L springs I don't unseat anymore.
Great job! I'm doing something similar fitting 33x10.50 on only a 1.25" BL and 3/4" front spacer with MCEs...but no where near as involved as your build.
Discussion Starter #11
If you have the 2.5L look for some stock 4.oL springs and you won't need the spacer. the 4.oL stock springs will give you enough lift to compensate for the weight of a winch.:D and thanks, I try to do what I can on what very little money I have to play with. I try not to send more then $100 per part. and other then the cage and gas tank skid I've been able to keep that $100.00 per part limit. CA's will break that limit when time comes for those too, unless I make them:D
Actually I have a 4.0 but the springs have 128k on them. i have the four stock springs from my old LJ with only 24K on them I am going to swap into the TJ. I figure the spacer will give me just a little more room in front. The LJ came with a hard top so chances are the spring rate difference may yield me a little lift.
Discussion Starter #13
ok that sounds like it would work.... do you have a winch on your jeep?
If you do you can get some 2" light duty lift springs to level your jeep back out.
I don't but I will have a winch eventually. I think the 3/4" spacer should get it fairly level unless the rear springs net me more lift than I think they will.
Gus-
I hope you can share photos when you get around to doing it. I may be going the same route unless I win the lotto and can afford the AEV highline kit.
Discussion Starter #16
Gus-
The AEV high line kit is tooo expensive!!! just read the forums and do it your self, its not that hard. Trust me I've done it. you just can't be afraid to cut your jeep a bit, like 3" off the hood.
Gus-
I have a build thread that links to our clubs forum. it is currently in the pics section but I'm getting it moved to the this builders section shortly. Although I haven't gotten to far yet...only had the jeep for a few weeks.
and here it is! Thanks RatherBinArizona! Our mods are the best!
http://www.wranglerforum.com/f118/link-to-gus-99-tj-build-143726.html
Nice build, I really like how you did the long travel shock mounts with the ford towers. If you make control arms with JJ's or similar on both ends you will be over the 100 limit. 40 per end, 10 per threaded insert and around 20 for the tube. I like your rear axle shock mounts too. I got some 4" wide 3/16" steel plate that could me made into those.
I'm planning on doing the high line with my tube fenders too. How are you going to measure for the cutout of the rear. May be a good idea to ask someone with genright hi-line fenders how much they cut off. That way later if you want fenders in the rear you can buy those to put on. Or if you cut to much out getting corner guards should cover it back up nicely. Also are you planning on covering up the gap that was made when you moved the fenders up? I think I will just try to extend the rocker guards out and box in that section.
Also do you care to give the length or model of shocks you used. Would like to see how much travel you gained doing that.
I'd like to know as much about those long travels as possible. I'd like to do that when I lift but I wouldn't know the first place to start. I'm going to run OME 2.5" springs and currie arms all the way around and I feel like the shocks are really gonna hold me back on flex. Thanks for any advice
1 - 20 of 126 Posts
