I agree, in a perfect world, it would/will be tied to the cage in some way... Also on the list of things to do...U.S.MarineLJ said:I think that thing would buckle under the weight of the Jeep in the event of a rollover. I believe most functional stingers have more reinforcment then just being bolted to the frame.![]()
Point of the bar is twofold - to make sure the strap doesn't slide down the side on steep climbs (people, not vehicles attached to the other end) and for a quick place to hook the winch hook when on the trail (yes, it will get a winch). And it's actually a flag tab, not a light tab. When you go to the dunes on the other side of the state, they require a tall orange flag.tweba99 said:Looks good, but what is the point of the bar at the top with the light tab?
Also, FWIW, PS comp stingers tie into the front upper coil spring bucket mounts for support. It will definitely not hold up if front pressure is put on it without any support.
jeeperman said:Point of the bar is twofold - to make sure the strap doesn't slide down the side on steep climbs (people, not vehicles attached to the other end) and for a quick place to hook the winch hook when on the trail (yes, it will get a winch). And it's actually a flag tab, not a light tab. When you go to the dunes on the other side of the state, they require a tall orange flag.
