what vehicle dod that come out of? How did you strip it Sandblaster?
1987 wagoneer. Nope all by hand, no one I know has a big enough blasting cabnet. I used por-15 there cleaner and metal prep, then used there bear metal grey paint.
Yes I did, and i've started working on that also. I don't like the dana 44 hub/rotor thing. The dana 30 allows you to remove the rotor and replace/turn it with out messing with the bearings. I'm not looking forward to the next time I have to do a brake job. Although they are made for a much heavier vehicle so I dont think I'll have to do it as often.
You will be much better off with the D44 that the D30!
