So I have been putting my audio system together piece by piece. The stock TJ sound system leaves plenty to be desired, especially if you don’t have the factory subwoofer, like mine. Replacing the cheap OEM radio with an aftermarket stereo kicks it up a bit, but the small 4x6” speakers in the dash are overpowered by the rear soundbar; if you fade it all to the front, you lose all your mid and low bass. There are certainly a few major design problems that need to be overcome to achieve a truly good sound!
I replaced my stereo with my Alpine from my old car – an Alpine CDA-117. This stereo is one of Alpine’s higher end radios; 3 sets of 4 volt pre-outs for amps, plenty of EQ adjustments, highpass and lowpass filters, and my favorite: time alignment! This fine tunes your sound stage by taking into account the distance each speaker is from the listener. It makes minute changes in the timing of each speaker and helps create an accurate soundstage right in front of the listener. When adjusted properly, this can make all the difference in the world with getting an accurate sound in the difficult environment of our TJ’s. The radio also has a rear USB input for iPods and flash drives, and I also got the KCA-400BT Bluetooth adapter for hands free phoning and audio streaming.
My TJ had some cheap Pioneer 4x6” speakers mounted in the dash, a slight improvement over stock, but still not near where I wanted it. After some researching and measuring, I decided on Pioneer’s D-Series 5.25” component speakers. I wanted a component set with a separate tweeter to help with the soundstage. I mounted the 5.25” woofer under the dash in the stock location, but used the tweeter pods that the speaker set came with to mount the tweeters on the top of the dash. High frequency sound is extremely directional, meaning it needs to be aimed almost directly at the listener in order for the sound stage to remain accurate. Lower frequencies are not as directional, so it is harder for the listener to perceive where the sound is coming from; that allows subwoofers to be mounted in a trunk without affecting the sound quality. I made some MDF rings for the woofers and used the 6x8” adapters that the speaker set came with to mount the woofers in the stock locations. I did have to cut a corner off each adapter plate to clear one of the metal sub dash brackets, but a Dremel tool made quick work of that. The MDF rings were added to strengthen the mounts and reduce any flexing or vibration; probably not absolutely necessary, but I would certainly recommend it if you choose to mount your speakers in the same way. I found some pretty good locations for crossovers, too; see the pictures.
The soundbar presented another problem for me. Having speakers directly behind the front listeners’ head made the rear speakers seem louder, and really screwed up the sound stage. Instead of hearing the sound coming from in front of you, most of it was heard from behind, like you have your back turned to a concert. Like I said before, the higher the frequency, the more directional it becomes. This made me decide to experiment a bit with my Focal 6.5” component speakers. I decided to only use the woofers for the rear channel. I kept the crossovers wired inline, so the woofers only play the mid and low frequencies, and all the high frequencies only come from the front channel. This actually turned out better than I thought it would. My next step is to add a 5 channel amp, but even running the speakers off the Alpine’s amp, the system sounds much more in line with where I want it to be! The low frequencies are still lacking as far as volume goes, but the sound stage is much more accurate than before, and I know amping it up and getting my sub installed will get it right where I want it.
Future plans are for a Kicker IX1000.5 five channel digital amp, I will mount it under the driver’s dash to keep it high and dry and to keep all my precious cargo space. I also have an Elemental Designs SQ 10” sub on pre-order. I took inspiration from an idea I got (on this forum?) to make the sub enclosure in the rear seat cushion. The SQ10 is designed to work in extremely small enclosures (as small as small as 0.25 cubic feet), so my box will be a bit smaller than the plans I have seen on the forums.
Alpine stereo and Bluetooth mic mounted.
Front left crossover location
Front left woofer mounted
Front left woofer and tweeter.
Front right crossover location
Front right woofer mounted
Front right woofer and tweeter
MDF ring for front woofers
Front woofers behind the factory grilles
Rear woofers mounted in the soundbar
Let me know what you all think! I can’t wait until it’s all put together, and I will be keeping this thread updated as I go, so check back later!
