Pop off the dash top useing a flathead screwdriver put tape on end to prevent scratching start in back corners ,then remove panel in front of shifter gentle pull will pull it off .theres four 7mm srews two up top at radio and two down low then pull whole center stack surround off wich will expose two more srews then you should be able to remove radio ..good luck
Thanks
Thanks RB-10rubicon,
Finally had time to pop the radio out. Was a little nervous when popping the surround off at the ac, but it worked. Hooked up the mic (I attached by the radio hoping to cut down on the wind noise). Did the U-Connect thing and taadaa. My Iphone is paired up and working.
Thanks a lot.:cool:
