I'm not sure, but I have the same connector in my 2011. It might go to the mic in the A pillar. I replaced my head unit with aftermarket and that plug didn't get used (though it was originally plugged into my OEM head unit). I can still make Bluetooth calls, but it may be using the mic built into my head unit rather than the one by the A pillar. I haven't really dug deeper since everything I wanted the head unit to do, it does.
This is the extension connector that goes down to the USB or bluetooth module, forgot which one but I had that same connector. Mystery solved. If you pull out the climate control dial plate, you will see it terminate down there.
