I am looking for a leaf spring from procomp brand.
My right rear one is sagging, i just need to replace that one.
its a 4" leaf spring lift.
If you just replace that one you might not be fixing anything. Because springs wear differently from Jeep to Jeep you would be better off buying new springs than used. I had the same thing happen but on the left (procomp 4" lift springs also). I ended up finding out that the stock shackles were limiting that spring from moving and forcing it to wear and sag different. So I put in new greaseable shackles and put them on. While I was at it I put the left spring on the right and right on left. I can still see it sagging, but month by month its getting better.
This is only a temp fix, its not long term. Doing this until i get some $$ saved up for RE 1.5" Lift for SOA. Even if its used but okay condition lead spring ill take.
