Just looking for factory specs on my 2 door JK 2015 to make sure its back to factory after leveling kit
thanks
P Scott
It should still be within spec after the very mild lift provided by the leveling kit but keep in mind the only thing you can adjust in stock form is Toe angle. The adjustment that is most often required after a lift is Caster angle and that will require a pair of front lower adjustable control arms.
Even if Caster angle is slightly off spec, drive it for a while and see how it feels. Low Caster Angle makes the steering feel flighty. If it feels OK then no Caster adjustment should be necessary. It is very subjective.
