1 - 17 of 17 Posts
Well went to open up the front diff to verify gears and found this..
To me this looks like a locker am I correct? When you spin the wheels they turn the same way, hold one and the other still spins... Let me know asap looking to order the parts for the rear. Thanks!
Also ring gear is stamped D30-410R which means dana 30 4.10 ratio correct?
I think the R means reverse rotation.
So from what I can see this is a Dana 30 HP from a Cherokee as it has a vac connection. Main question I have is does that look like a locker or not? Someone has to know. Thanks!
From your pics we can't see what we need to see. Turn to where we can look into the window of the middle area and not the outside wall of it.
WOW! You need to rebuild. Your pinion is rubbing the carrier. That's why it had those cuts into it. How come nobody has said anything? And if you can hold one and the other spins then it isn't a locker...
Figured as much and in the process when all the parts come I will. As far as looking into a "window" not to sure what is meant by that but that thing is solid, no open areas. Could it be a LSD, the dana 30's didnt come stock with lockers correct? Sorry for all the stupid/newb questions as I am new to jeeps.
I will pop the cover and look again today for what you say but if I remember right that is a full solid case. There was no holes or signs of spider gears anywhere. Curious since this has the vac disconnect if the axles are not locked that could be why it's not acting like a locker correct? Going to jack it back up and test this theory later today.
it is not an open carrier, if you turn one tire and it spins the opposite direction it is an open diff, if you turn a tire and it spins the same direction its not open, it doesn't look like an open carrier either.. its more than likely an automatic locker, like a lunchbox locker. Also the R indicates Reverse cut which all high pinion gears are.
Its likely not a cherokee axle as was suggested.. the stock YJ d30 was high pinion, and had the center axle disconnect.. i'm guessing someone has swapped in a solid passenger side axle shaft or else spinning one tire would do nothing at all to the other tire, unless you had the jeep turned on, put in 4wd, then turned it off..
Discussion Starter · #12 ·
Thank you! Exactly what I was saying about it, well after playing with it for a bit I figure thats what it is (cant test it till I re gear the rear). But I also discovered that I have a SYE installed on the Yj already as well as a cv shaft(sucks cause I have a sye kit on its way haha almost just ordered the new ds as well). But I do have quite a few more parts coming for the Yj in a few days so excited about that! Thanks guys
Read the op again... He said he can hold one tire and the other turns. That's just a carrier in dark's post. It doesn't even have guts in it. From the op picture you can't tell what it is because you can't see the guts in the carrier. And his carrier does look like the one in the picture... He has to rotate it some more to make it look like that...
Discussion Starter · #14 ·
Actually if you look at the picture you can see it looks NOTHING like the one dark pictured... It is a full SOLID case like a locker, this is why I thought it could be one. This has a vac disco which explains why only one tire spins and when the vac disco is engaged it does lock the axles. Im not to sure if I am not wording things right or what but seems like not all of it is gettin read before someone posts. please read all and every comment. Dont get me wrong I am glad for the help but dont think it is to much to ask to read before you post.
To me this looks like a locker am I correct? When you spin the wheels they turn the same way, HOLD ONE AND THE OTHER STILL SPINS... Let me know asap looking to order the parts for the rear. Thanks!
This is your first post... I just capitalized the important stuff. I'm just going by this.
1 - 17 of 17 Posts
